跳转到主内容
Lenovo IdeaPad U310 Screen Replacement
你所需要的
  1. Lenovo IdeaPad U310 Screen  Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the device over so the bottom panel is facing up.
    • Remove the rubber feet by pinching and pulling in an upward motion.
    • The rubber feet are missing from this photo, but will be located within the red markups.
  2. Lenovo IdeaPad U310 Screen  Replacement: 步骤 2 中的图像 1,1
    • Remove the 4 screws securing the bottom panel to the device.
    • The screws are missing from this device and are not pictured. They will be located under the rubber feet within the red markups.
  3. Lenovo IdeaPad U310 Screen  Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad U310 Screen  Replacement: 步骤 3 中的图像 2,2
    • Place the plastic opening tool between the bottom panel and device.
    • Pry around the device's outer edge until the bottom panel is no longer attached.
    • Lift the bottom panel up and away from device.
  4. Lenovo IdeaPad U310 Screen  Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad U310 Screen  Replacement: 步骤 4 中的图像 2,2
    • Unplug the Battery from the circuit board by carefully prying the connector from its housing.
  5. Lenovo IdeaPad U310 Screen  Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad U310 Screen  Replacement: 步骤 5 中的图像 2,2
    • Remove the 5.6 mm Screw with the PH1 screwdriver.
    • Remove the 4.6 mm screws with the PH1 screwdriver.
  6. Lenovo IdeaPad U310 Screen  Replacement: 步骤 6 中的图像 1,2 Lenovo IdeaPad U310 Screen  Replacement: 步骤 6 中的图像 2,2
    • Lift the strip tape away from the battery, being careful not to completely remove it.
  7. Lenovo IdeaPad U310 Screen  Replacement: 步骤 7 中的图像 1,1
    • Remove the battery by lifting up and away from device.
  8. Lenovo IdeaPad U310 Screen  Replacement, Screen: 步骤 8 中的图像 1,1
    • Insert opening tool between the frame and the back panel of the screen.
  9. Lenovo IdeaPad U310 Screen  Replacement: 步骤 9 中的图像 1,1
    • Work your way around the frame until every connection is loose.
  10. Lenovo IdeaPad U310 Screen  Replacement: 步骤 10 中的图像 1,1
    • Lift the screen up and away from the device.
    • Do not tamper with the tape on the bottom of the screen labeled "Don't touch".
  11. Lenovo IdeaPad U310 Screen  Replacement: 步骤 11 中的图像 1,2 Lenovo IdeaPad U310 Screen  Replacement: 步骤 11 中的图像 2,2
    • Remove the 1.9 mm screws using the PH0 screwdriver.
    • These screws are very short and small, keep track of them.
  12. Lenovo IdeaPad U310 Screen  Replacement: 步骤 12 中的图像 1,2 Lenovo IdeaPad U310 Screen  Replacement: 步骤 12 中的图像 2,2
    • Once the four screws are removed, gently rest the screen facedown on the keyboard.
  13. Lenovo IdeaPad U310 Screen  Replacement: 步骤 13 中的图像 1,2 Lenovo IdeaPad U310 Screen  Replacement: 步骤 13 中的图像 2,2
    • Peel back the white tape, revealing the power connection.
  14. Lenovo IdeaPad U310 Screen  Replacement: 步骤 14 中的图像 1,2 Lenovo IdeaPad U310 Screen  Replacement: 步骤 14 中的图像 2,2
    • Unplug the connector, pulling it by the white tape.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 19
总计 5,113
