跳转到主内容
Lenovo IdeaPad U310 Ram Replacement
你所需要的
  1. Lenovo IdeaPad U310 Ram  Replacement, RAM: 步骤 1 中的图像 1,1
    • Make sure device is turned off and disconnected from any power source before proceeding.
    • Flip the device over so the bottom panel is facing up.
    • Remove the rubber feet by pinching and pulling in an upward motion.
    • The rubber feet are missing from this photo, but will be located within the red markups.
  2. Lenovo IdeaPad U310 Ram  Replacement: 步骤 2 中的图像 1,1
    • Remove the 4 screws securing the bottom panel to the device.
    • The screws are missing from this device and are not pictured. They will be located under the rubber feet within the red markups.
  3. Lenovo IdeaPad U310 Ram  Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad U310 Ram  Replacement: 步骤 3 中的图像 2,2
    • Place the plastic opening tool between the bottom panel and device.
    • Pry around the device's outer edge until the bottom panel is no longer attached.
    • Lift the bottom panel up and away from device.
  4. Lenovo IdeaPad U310 Ram  Replacement: 步骤 4 中的图像 1,1
    • Pry the RAM's two holding clips in an outward motion.
  5. Lenovo IdeaPad U310 Ram  Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad U310 Ram  Replacement: 步骤 5 中的图像 2,2
    • Continue to pry open the clips, and slip the RAM from its housing.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 2,526
