跳转到主内容
Lenovo IdeaPad U310 Fan Replacement
你所需要的
  1. Lenovo IdeaPad U310 Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the device over so the bottom panel is facing up.
    • Remove the rubber feet by pinching and pulling in an upward motion.
    • The rubber feet are missing from this photo, but will be located within the red markups.
  2. Lenovo IdeaPad U310 Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the 4 screws securing the bottom panel to the device.
    • The screws are missing from this device and are not pictured. They will be located under the rubber feet within the red markups.
  3. Lenovo IdeaPad U310 Fan Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad U310 Fan Replacement: 步骤 3 中的图像 2,2
    • Place the plastic opening tool between the bottom panel and device.
    • Pry around the device's outer edge until the bottom panel is no longer attached.
    • Lift the bottom panel up and away from device.
  4. Lenovo IdeaPad U310 Fan Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad U310 Fan Replacement: 步骤 4 中的图像 2,2
    • Unplug the Battery from the circuit board by carefully prying the connector from its housing.
  5. Lenovo IdeaPad U310 Fan Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad U310 Fan Replacement: 步骤 5 中的图像 2,2
    • Remove the 5.6 mm Screw with the PH1 screwdriver.
    • Remove the 4.6 mm screws with the PH1 screwdriver.
  6. Lenovo IdeaPad U310 Fan Replacement: 步骤 6 中的图像 1,2 Lenovo IdeaPad U310 Fan Replacement: 步骤 6 中的图像 2,2
    • Lift the strip tape away from the battery, being careful not to completely remove it.
  7. Lenovo IdeaPad U310 Fan Replacement: 步骤 7 中的图像 1,1
    • Remove the battery by lifting up and away from device.
  8. Lenovo IdeaPad U310 Fan Replacement, Fan: 步骤 8 中的图像 1,2 Lenovo IdeaPad U310 Fan Replacement, Fan: 步骤 8 中的图像 2,2
    • Unplug fan by pinching the connector and pulling it away from its housing.
  9. Lenovo IdeaPad U310 Fan Replacement: 步骤 9 中的图像 1,2 Lenovo IdeaPad U310 Fan Replacement: 步骤 9 中的图像 2,2
    • Unscrew 5.1 mm screw using PH1.
    • Unscrew the four 3.6 mm screws using PH1.
    • Theses five screws are attached to the black plate with rubber stoppers. You will be able to loosen them from the circuit board, but they will stay attached.
  10. Lenovo IdeaPad U310 Fan Replacement: 步骤 10 中的图像 1,1
    • Remove fan by lifting up and away from device.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 1,590
