跳转到主内容
Lenovo IdeaPad S400 Touch RAM Replacement
你所需要的
  1. Lenovo IdeaPad S400 Touch RAM Replacement, Battery: 步骤 1 中的图像 1,3 Lenovo IdeaPad S400 Touch RAM Replacement, Battery: 步骤 1 中的图像 2,3 Lenovo IdeaPad S400 Touch RAM Replacement, Battery: 步骤 1 中的图像 3,3
    • Turn your computer over so the back is face up.
    • Use your forefinger to unlock the two tabs located on the back. Slide the tabs until you see the red showing.
    • The battery cover will then pop up allowing you access to the battery.
  2. Lenovo IdeaPad S400 Touch RAM Replacement, RAM: 步骤 2 中的图像 1,3 Lenovo IdeaPad S400 Touch RAM Replacement, RAM: 步骤 2 中的图像 2,3 Lenovo IdeaPad S400 Touch RAM Replacement, RAM: 步骤 2 中的图像 3,3
    • Remove the five 6mm Phillips #0 screws from the back panel.
    • Pull back the rubber tabs from the corners of the laptop backing to expose the screws.
    • The two tabs next to the battery flip toward the battery. The two remaining tabs flip down, away from the battery.
    • Remove the four 4mm Phillips #0 screws that are underneath the rubber tabs.
    • Remove the three 6mm Phillips #0 screws from under the battery.
  3. Lenovo IdeaPad S400 Touch RAM Replacement: 步骤 3 中的图像 1,1
    • Slide the back panel away to remove it.
    • Don't be afraid to apply force when removing the back panel.
  4. Lenovo IdeaPad S400 Touch RAM Replacement: 步骤 4 中的图像 1,3 Lenovo IdeaPad S400 Touch RAM Replacement: 步骤 4 中的图像 2,3 Lenovo IdeaPad S400 Touch RAM Replacement: 步骤 4 中的图像 3,3
    • Push the metal arms away from the RAM.
    • The RAM should pop up.
    • Pull the RAM out.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 676
