跳转到主内容
Lenovo IdeaPad S400 Touch Fan Replacement
你所需要的
  1. Lenovo IdeaPad S400 Touch Fan Replacement, Battery: 步骤 1 中的图像 1,3 Lenovo IdeaPad S400 Touch Fan Replacement, Battery: 步骤 1 中的图像 2,3 Lenovo IdeaPad S400 Touch Fan Replacement, Battery: 步骤 1 中的图像 3,3
    • Turn your computer over so the back is face up.
    • Use your forefinger to unlock the two tabs located on the back. Slide the tabs until you see the red showing.
    • The battery cover will then pop up allowing you access to the battery.
  2. Lenovo IdeaPad S400 Touch Fan Replacement, Fan: 步骤 2 中的图像 1,3 Lenovo IdeaPad S400 Touch Fan Replacement, Fan: 步骤 2 中的图像 2,3 Lenovo IdeaPad S400 Touch Fan Replacement, Fan: 步骤 2 中的图像 3,3
    • Remove the five 6mm Phillips #0 screws from the back panel.
    • Pull back the rubber tabs from the corners of the laptop backing to expose the screws.
    • The two tabs next to the battery flip toward the battery. The two remaining tabs flip down, away from the battery.
    • Remove the four 4mm Phillips #0 screws that are underneath the rubber tabs.
    • Remove the three 6mm Phillips #0 screws from under the battery.
  3. Lenovo IdeaPad S400 Touch Fan Replacement: 步骤 3 中的图像 1,1
    • Slide the back panel away to remove it.
    • Don't be afraid to apply force when removing the back panel.
  4. Lenovo IdeaPad S400 Touch Fan Replacement: 步骤 4 中的图像 1,1
    • Remove the two 5mm Phillips #0 screws holding the fan down.
  5. Lenovo IdeaPad S400 Touch Fan Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad S400 Touch Fan Replacement: 步骤 5 中的图像 2,2
    • Unplug the fan's power supply cord.
  6. Lenovo IdeaPad S400 Touch Fan Replacement: 步骤 6 中的图像 1,1
    • Pull the fan out.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 426
