跳转到主内容
Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement
你所需要的
  1. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Back Panel: 步骤 1 中的图像 1,2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: 步骤 2 中的图像 1,1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 1,2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 2,2
    • Pull up the black foam adhesive that covers the screw and connectors holding the Wi-Fi card in place.
  4. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: 步骤 4 中的图像 2,2
    • Using an opening tool, lift up on the black and white coaxial cables on the Wi-Fi card and gently pull upward to unplug them.
    • When reconnecting the cables, be sure to match the colors to the arrows on the Wi-Fi card.
  5. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: 步骤 5 中的图像 2,2
    • Remove the single 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
    • Gently lift the Wi-Fi card out of the computer.
结论
Kristen Gismondi
于11/12/14注册
82,822 声望
创作了203篇指南
团队
iFixit iFixit 的会员
Staff
137 名成员
创作了17,457篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 27
过去 30 天: 59
总计 1,078
