你所需要的
Power off the laptop and place it face-down on a non-scratching surface.
Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
Disconnect the battery cable by gently pulling it straight out of the connector.
Remove the battery from the laptop.
Unplug the wire connecting the speakers to the motherboard.
Remove the speakers from each side of the laptop.
即将完成!
结论
