跳转到主内容
Lenovo IdeaPad S340-15IWL CMOS Battery Replacement
你所需要的
  1. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement: 步骤 2 中的图像 1,1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, CMOS Battery: 步骤 3 中的图像 1,3 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, CMOS Battery: 步骤 3 中的图像 2,3 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, CMOS Battery: 步骤 3 中的图像 3,3
    • Remove the circular CMOS battery on the far left side of the computer by lifting it with your finger or an opening tool.
    • This is only attached with adhesive, so it does not require extensive force.
  4. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement: 步骤 4 中的图像 2,2
    • Unplug the bundled red and black wires connecting the CMOS battery to the side of the device.
    • Remove the CMOS battery from the laptop.
结论
2等其他人完成本指南。
Kristen Gismondi
于11/12/14注册
82,822 声望
创作了203篇指南
团队
iFixit iFixit 的会员
Staff
137 名成员
创作了17,457篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 33
过去 30 天: 142
总计 1,698
