跳转到主内容
Lenovo IdeaPad S340-15IWL Battery Replacement
你所需要的
  1. Lenovo IdeaPad S340-15IWL Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 Lenovo IdeaPad S340-15IWL Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Battery Replacement: 步骤 2 中的图像 1,1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Battery Replacement, Battery: 步骤 3 中的图像 1,2 Lenovo IdeaPad S340-15IWL Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Disconnect the battery cable by gently pulling it straight out of the connector.
    • Be sure to pull parallel to the device to avoid bending the motherboard connector.
    • The battery connector does not lock and only requires light pressure to insert and remove.
    • Remove the battery from the laptop.
结论
2等其他人完成本指南。
一条评论
Worked wonderfully. Thanks for the great instructions.
Deb Dhar - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 44
过去 30 天: 139
总计 5,455
