跳转到主内容
Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement
你所需要的
  1. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure your device is unplugged and shut down.
    • Place the laptop down with the cooling vents facing upwards.
  2. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: 步骤 2 中的图像 2,2
    • Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
    • Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
  3. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement, Back Panel: 步骤 3 中的图像 1,2 Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement, Back Panel: 步骤 3 中的图像 2,2
    • Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
  4. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: 步骤 4 中的图像 1,1
    • Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
  5. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: 步骤 5 中的图像 1,3 Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: 步骤 5 中的图像 2,3 Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: 步骤 5 中的图像 3,3
    • Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
  6. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement, Wi-Fi Network Card: 步骤 6 中的图像 1,2 Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement, Wi-Fi Network Card: 步骤 6 中的图像 2,2
    • Remove both antenna wires by pulling upwards gently.
  7. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: 步骤 7 中的图像 1,1
    • Using the #00 Phillips screwdriver, remove one 3mm screw from the network card.
  8. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: 步骤 8 中的图像 1,2 Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: 步骤 8 中的图像 2,2
    • Slide Wi-Fi network card away from motherboard and remove gently.
结论
Zack Colman
于07/08/19注册
885 声望
创作了8篇指南
2条评论
Can I swap out the card with another make/model? If I don’t want to use a dongle and my OS doesn’t support the original one.
How do I know which will fit?
neb🇳🇴 - 回复
Many months later:
I replaced the card and booted up. No BIOS, just straight to error message:
"Unauthorized Wireless network card is plugged in. Power off and remove it."
Very sly move, Lenovo!
Now I need special hard- and software tools to modify UEFI!
neb🇳🇴 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 324
