跳转到主内容
Lenovo IdeaPad S210 Touch Hard Drive Replacement
你所需要的
  1. Lenovo IdeaPad S210 Touch Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure your device is unplugged and shut down.
    • Place the laptop down with the cooling vents facing upwards.
  2. Lenovo IdeaPad S210 Touch Hard Drive Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad S210 Touch Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
    • Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
  3. Lenovo IdeaPad S210 Touch Hard Drive Replacement, Back Panel: 步骤 3 中的图像 1,2 Lenovo IdeaPad S210 Touch Hard Drive Replacement, Back Panel: 步骤 3 中的图像 2,2
    • Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
  4. Lenovo IdeaPad S210 Touch Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
  5. Lenovo IdeaPad S210 Touch Hard Drive Replacement: 步骤 5 中的图像 1,3 Lenovo IdeaPad S210 Touch Hard Drive Replacement: 步骤 5 中的图像 2,3 Lenovo IdeaPad S210 Touch Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
  6. Lenovo IdeaPad S210 Touch Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,2 Lenovo IdeaPad S210 Touch Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 2,2
    • Using a #0 Phillips screwdriver, remove the four 4mm screws that secure the hard drive bracket to the motherboard.
  7. Lenovo IdeaPad S210 Touch Hard Drive Replacement: 步骤 7 中的图像 1,2 Lenovo IdeaPad S210 Touch Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Slide your hard drive away from your motherboard until fully removed.
    • Be careful not to snag any wires routed along the battery side of the hard drive.
  8. Lenovo IdeaPad S210 Touch Hard Drive Replacement: 步骤 8 中的图像 1,3 Lenovo IdeaPad S210 Touch Hard Drive Replacement: 步骤 8 中的图像 2,3 Lenovo IdeaPad S210 Touch Hard Drive Replacement: 步骤 8 中的图像 3,3
    • This step is only necessary if you are swapping your old hard drive for a new one.
    • Using a Phillips #0 screwdriver, remove four 2.5mm screws, two per side, to release the hard drive from its mounting bracket. These screws are directly next to each mounting screw you removed previously.
    • Install the mounting brackets onto the new hard drive during reassembly.
结论
2等其他人完成本指南。
Zack Colman
于07/08/19注册
885 声望
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,387
