跳转到主内容
加入维修社区 - 创建账户
Lenovo IdeaPad S10-2 Keyboard Replacement
你所需要的
  1. Lenovo IdeaPad S10-2 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Rotate the laptop so the back side is facing you.
    • From this side, you should be able to see both of the gaps where the two plastic materials meet.
  2. Lenovo IdeaPad S10-2 Keyboard Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad S10-2 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Wedge the nylon or metal spudger inside the gap and pry open the two plastic parts.
  3. Lenovo IdeaPad S10-2 Keyboard Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad S10-2 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Open the laptop.
    • Place the nylon or metal spudger under the top half that is loose and pull up to pry it open.
  4. Lenovo IdeaPad S10-2 Keyboard Replacement: 步骤 4 中的图像 1,3 Lenovo IdeaPad S10-2 Keyboard Replacement: 步骤 4 中的图像 2,3 Lenovo IdeaPad S10-2 Keyboard Replacement: 步骤 4 中的图像 3,3
    • Pull up on the loose component to remove.
    • As you lift the keyboard, you should be able to see a strip connected to the laptop.
  5. Lenovo IdeaPad S10-2 Keyboard Replacement: 步骤 5 中的图像 1,3 Lenovo IdeaPad S10-2 Keyboard Replacement: 步骤 5 中的图像 2,3 Lenovo IdeaPad S10-2 Keyboard Replacement: 步骤 5 中的图像 3,3
    • Remove the strip by pulling both sides of the blue strip out.
    • Lift and remove the keyboard from the laptop.
结论
2等其他人完成本指南。
Mary
于10/13/15注册
132 声望
撰写一个指南
团队
1指南评论
Thanks! Just be careful when inserting the keyboard strips back into it's socket: that socket has retainer that needs to be released before inserting the strip. It is highlighted with different color, maybe brown. To release the strip pull the retainer in the same direction as when pulling out the keyboard strip, but do it before pulling that strip, so the strip will be released easily and can be inserted back when needed. Then push the retainer back...
Roman Vasylenko - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 3,426
