跳转到主内容
Lenovo IdeaPad N586 Keyboard Replacement
你所需要的
  1. Lenovo IdeaPad N586 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove three screws on bottom of case. They have a little keyboard image next to them. If you don't do this first, the keyboard will not come off. Place the plastic spudger right under the edge of the keyboard and lift up the keyboard.
  2. Lenovo IdeaPad N586 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Slowly and gently lift the keyboard up to separate from the chassis.
  3. Lenovo IdeaPad N586 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Gently lift the keyboard off the chassis.
    • Carefully disconnect the keyboard from the laptop by unhooking the keyboard ribbon.
  4. Lenovo IdeaPad N586 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Now remove the keyboard from the computer.
结论
另外一个人完成了本指南。
Christopher
于04/08/14注册
676 声望
创作了6篇指南
团队
Cal Poly, Team 8-7, Regan Spring 2014 Cal Poly, Team 8-7, Regan Spring 2014 的会员
CPSU-REGAN-S14S8G7
5 名成员
创作了10篇指南
一条评论
WARNING!!!!!!
These steps do not include removing the three screws that secure the keyboard to the bottom of the latop!!! They are marked with tiny keyboard icons. One is under the bottom panel, so that has to be removed first.
Clint Hatchett - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 1,839
