跳转到主内容
Lenovo IdeaPad N586 Hard Drive Replacement
你所需要的
  1. Lenovo IdeaPad N586 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 Lenovo IdeaPad N586 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
  2. Lenovo IdeaPad N586 Hard Drive Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad N586 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Now push the right clip to the right and hold it while using your other hand to pull the battery out.
  3. Lenovo IdeaPad N586 Hard Drive Replacement, Back Panel: 步骤 3 中的图像 1,1
    • Remove the two screws highlighted.
  4. Lenovo IdeaPad N586 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • This is the back of the laptop with the cover removed.
  5. Lenovo IdeaPad N586 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Now remove the last two screws highlighted
  6. Lenovo IdeaPad N586 Hard Drive Replacement: 步骤 6 中的图像 1,2 Lenovo IdeaPad N586 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Push hard drive away from the center of the chassis.
    • Lift the hard drive out of the chassis using the tab located on the drive.
结论
Christopher
于04/08/14注册
676 声望
创作了6篇指南
团队
Cal Poly, Team 8-7, Regan Spring 2014 Cal Poly, Team 8-7, Regan Spring 2014 的会员
CPSU-REGAN-S14S8G7
5 名成员
创作了10篇指南
一条评论
Please include that the back panel SLIDES out. I pried it out and broke off three of the retaining tabs. It easily slides out, and it would have been nice if that was in the directions. Most laptops panels are pried out.
stephenkingsley - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 2,152
