跳转到主内容
Lenovo IdeaPad N580 CPU Replacement
你所需要的
  1. Lenovo IdeaPad N580 CPU Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn over the device so that the bottom is facing up. Make sure the hinged side is facing you.
  2. Lenovo IdeaPad N580 CPU Replacement: 步骤 2 中的图像 1,1
    • Move the right switch towards the right until it clicks in place. You should then see the color red reveal from where the switch was originally.
  3. Lenovo IdeaPad N580 CPU Replacement: 步骤 3 中的图像 1,1
    • Now take your left hand and slide the left switch to the left.
    • This switch will not click in place like the other switch, so make sure to keep your left hand on the switch.
  4. Lenovo IdeaPad N580 CPU Replacement: 步骤 4 中的图像 1,1
    • Take your free hand and place it on the battery. Gently slide it away from its slot.
  5. Lenovo IdeaPad N580 CPU Replacement, Keyboard and Trackpad: 步骤 5 中的图像 1,3 Lenovo IdeaPad N580 CPU Replacement, Keyboard and Trackpad: 步骤 5 中的图像 2,3 Lenovo IdeaPad N580 CPU Replacement, Keyboard and Trackpad: 步骤 5 中的图像 3,3
    • Rotate the laptop so that now the hinge is facing away from you.
    • Remove the two 2.5 x 4.0 mm Phillips #0 screws from the underside of the laptop.
    • Slide the bottom panel towards you until it stops, and then carefully lift it off.
  6. Lenovo IdeaPad N580 CPU Replacement: 步骤 6 中的图像 1,1
    • Remove the three 2.0 x 6.0 mm Phillips #0 screws located on the underside of the device.
  7. Lenovo IdeaPad N580 CPU Replacement: 步骤 7 中的图像 1,3 Lenovo IdeaPad N580 CPU Replacement: 步骤 7 中的图像 2,3 Lenovo IdeaPad N580 CPU Replacement: 步骤 7 中的图像 3,3
    • Turn the laptop right side up and open the lid.
    • Using the spudger and your fingers, get in between the keyboard's edge and lift it up.
    • Carefully lift the keyboard ribbon cable out of the socket it is in.
  8. Lenovo IdeaPad N580 CPU Replacement: 步骤 8 中的图像 1,2 Lenovo IdeaPad N580 CPU Replacement: 步骤 8 中的图像 2,2
    • Remove the 2.5 x 6.0 mm Phillips #0 from the center of the device.
    • Close the laptop and place it face down once again.
  9. Lenovo IdeaPad N580 CPU Replacement: 步骤 9 中的图像 1,1
    • If a hard disk drive is installed, remove the two 2.5 x 4.0 mm Phillips #0 screws.
    • Slide the hard disk drive out of its socket.
  10. Lenovo IdeaPad N580 CPU Replacement: 步骤 10 中的图像 1,1
    • Remove the eleven 2.5 x 6.0 mm Phillips #0 screws.
    • Remove the three 2.0 x 3.0 mm flat head screws.
    • Remove the 2.5 x 4.0 mm Phillips #0 screw.
  11. Lenovo IdeaPad N580 CPU Replacement: 步骤 11 中的图像 1,2 Lenovo IdeaPad N580 CPU Replacement: 步骤 11 中的图像 2,2
    • Disconnect the two ribbon cables from the center.
    • Lift the keyboard bezel (with trackpad) straight up and out.
  12. Lenovo IdeaPad N580 CPU Replacement, Motherboard: 步骤 12 中的图像 1,1
    • Remove the five ribbon cables on the top of the computer.
    • Gently remove the single cable from its socket.
  13. Lenovo IdeaPad N580 CPU Replacement: 步骤 13 中的图像 1,1
    • Remove the three 2.5 x 3.0 mm Phillips #0 screws on the motherboard.
  14. Lenovo IdeaPad N580 CPU Replacement: 步骤 14 中的图像 1,2 Lenovo IdeaPad N580 CPU Replacement: 步骤 14 中的图像 2,2
    • Using your fingers or a spudger, lift the motherboard slightly.
    • Detach the single cable from underneath.
    • Lift the motherboard the rest of the way out.
  15. Lenovo IdeaPad N580 CPU Replacement, CPU: 步骤 15 中的图像 1,1
    • Detach the cable next to the fan assembly.
  16. Lenovo IdeaPad N580 CPU Replacement: 步骤 16 中的图像 1,2 Lenovo IdeaPad N580 CPU Replacement: 步骤 16 中的图像 2,2
    • Remove the three 2.0 x 3.2 mm Phillips #0 screws from the fan.
    • Lift the fan straight off the motherboard.
  17. Lenovo IdeaPad N580 CPU Replacement: 步骤 17 中的图像 1,2 Lenovo IdeaPad N580 CPU Replacement: 步骤 17 中的图像 2,2
    • Using a flathead screwdriver, turn the beige lock to counterclockwise to unlocked.
  18. Lenovo IdeaPad N580 CPU Replacement: 步骤 18 中的图像 1,1
    • Lift the CPU out of the socket.
    • Upon replacing the CPU and re-locking back in place, remember to apply thermal paste in order to prevent overheating.
结论
5等其他人完成本指南。
Alex Amorim
于03/19/18注册
907 声望
创作了5篇指南
团队
UMass Dartmouth, Team S5-G2, Peak Spring 2018 UMass Dartmouth, Team S5-G2, Peak Spring 2018 的会员
UMASSD-PEAK-S18S5G2
2 名成员
创作了5篇指南
一条评论
süper olmuş eline sağlık çok açıklayıcı ve başarılı olmuş teşekkür ederim
Ümit Kocamanoglu - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,083
