跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
If the device isn't powering on, then the issue may be due to the battery. Follow these steps to replace the battery.
  1. Turn over the device so that the bottom is facing up. Make sure the hinged side is facing you.
    • Turn over the device so that the bottom is facing up. Make sure the hinged side is facing you.
  2. Move the right switch towards the right until it clicks in place. You should then see the color red reveal from where the switch was originally.
    • Move the right switch towards the right until it clicks in place. You should then see the color red reveal from where the switch was originally.
  3. LCD iPhone 屏幕维修套装
    预算选项,涵盖在我们的终身保修中。
    购买套装
    LCD iPhone 屏幕维修套装
    削减维修成本,而不是质量。
    购买套装
  4. Now take your left hand and slide the left switch to the left.
    • Now take your left hand and slide the left switch to the left.
    • This switch will not click in place like the other switch, so make sure to keep your left hand on the switch.
  5. Take your free hand and place it on the battery. Gently slide it away from its slot.
    • Take your free hand and place it on the battery. Gently slide it away from its slot.
结论
Alex Amorim
于2018年03月19日注册
721 信誉积分
创作了5篇指南
团队
UMass Dartmouth, Team S5-G2, Peak Spring 2018 UMass Dartmouth, Team S5-G2, Peak Spring 2018 的会员
UMASSD-PEAK-S18S5G2
2 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 6
总计 121
