跳转到主内容
Lenovo IdeaPad G50-45 Screen Replacement
你所需要的
  1. Lenovo IdeaPad G50-45 Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Remove the bezel by using the iFixit plastic opening tool to lift up an edge.
    • The bezel is the plastic lining along the edge of the screen.
  2. Lenovo IdeaPad G50-45 Screen Replacement: 步骤 2 中的图像 1,1
    • Finish removing the bezel by using your hand on the inside of the screen and popping it off.
    • If part of the bezel is stuck, start on the opposite side and work your way back to the area that is stuck.
    • The plastic on the hinges will pop off with the rest of the bezel.
  3. Lenovo IdeaPad G50-45 Screen Replacement: 步骤 3 中的图像 1,3 Lenovo IdeaPad G50-45 Screen Replacement: 步骤 3 中的图像 2,3 Lenovo IdeaPad G50-45 Screen Replacement: 步骤 3 中的图像 3,3
    • Remove the 4 screws located in each corner of the screen using the Phillips #2 screwdriver.
  4. Lenovo IdeaPad G50-45 Screen Replacement: 步骤 4 中的图像 1,1
    • Peel back the sticker that attaches the connector to the back of the screen.
    • Disconnect the cable that connects the screen to the computer.
    • There may be two cables.
  5. Lenovo IdeaPad G50-45 Screen Replacement: 步骤 5 中的图像 1,1
    • Test the new screen by turning it on before putting the bezel back on.
结论
6等其他人完成本指南。
团队
UMass Dartmouth, Team 2-6, Shastany Fall 2015 UMass Dartmouth, Team 2-6, Shastany Fall 2015 的会员
UMASSD-SHASTANY-F15S2G6
3 名成员
创作了5篇指南
2条评论
The tutorial was pretty straightforward, and worked.
Remy G - 回复
My Laptop is got work the searen is blue it what trun on
Rebecca - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 39
总计 7,913
