跳转到主内容
Lenovo IdeaPad G50-45 Fan Replacement
你所需要的
  1. Lenovo IdeaPad G50-45 Fan Replacement, Fan: 步骤 1 中的图像 1,1
    • Safely flip the device upside down and use the Phillips head screwdriver to remove the 3 screws at the bottom of the device which are circled.
  2. Lenovo IdeaPad G50-45 Fan Replacement: 步骤 2 中的图像 1,1
    • Slide, do not lift, the bottom panel off once the 3 screws are off.
  3. Lenovo IdeaPad G50-45 Fan Replacement: 步骤 3 中的图像 1,1
    • Locate the fan in the upper right corner above the orange bar and appears as a silver semicircle.
  4. Lenovo IdeaPad G50-45 Fan Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad G50-45 Fan Replacement: 步骤 4 中的图像 2,2
    • Remove the 3 screws attaching the fan to the device.
  5. Lenovo IdeaPad G50-45 Fan Replacement: 步骤 5 中的图像 1,1
    • Once the screws are removed slowly lift the fan out, there will be a thin wire connected to the device and fan still, Firmly grasp the white end of the wire where the wire splits into 2 and pull it out.
  6. Lenovo IdeaPad G50-45 Fan Replacement: 步骤 6 中的图像 1,1
    • The fan should be removed now and appear as so.
结论
3等其他人完成本指南。
Robert Muir
于10/26/15注册
359 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-6, Shastany Fall 2015 UMass Dartmouth, Team 2-6, Shastany Fall 2015 的会员
UMASSD-SHASTANY-F15S2G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 2,961
