跳转到主内容
Lenovo IdeaPad G50-45 DVD Drive Replacement
你所需要的
  1. Lenovo IdeaPad G50-45 DVD Drive Replacement, DVD Drive: 步骤 1 中的图像 1,1
    • First, remove the three screws located on the bottom panel of the laptop using a Philips #2 screwdriver.
    • To avoid losing the small screws, put them in a container.
  2. Lenovo IdeaPad G50-45 DVD Drive Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad G50-45 DVD Drive Replacement: 步骤 2 中的图像 2,2
    • To remove the panel on the laptop, gently slide the panel away from the battery.
    • Make sure to slide the panel away before you lift to keep the panel from breaking.
    • Lift up the panel and place it to the side.
  3. Lenovo IdeaPad G50-45 DVD Drive Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad G50-45 DVD Drive Replacement: 步骤 3 中的图像 2,2
    • Remove the indicated screw holding the DVD Drive.
    • To avoid losing the screw, place it in the same container used to hold the other three screws.
  4. Lenovo IdeaPad G50-45 DVD Drive Replacement: 步骤 4 中的图像 1,1
    • Push the now-free tab towards the DVD Drive using a flathead screwdriver.
    • Do not pry up the now-free tab.
  5. Lenovo IdeaPad G50-45 DVD Drive Replacement: 步骤 5 中的图像 1,1
    • Lastly, pull out the DVD Drive; it should come out easily.
结论
6等其他人完成本指南。
Saulo Gomes
于10/26/15注册
601 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-6, Shastany Fall 2015 UMass Dartmouth, Team 2-6, Shastany Fall 2015 的会员
UMASSD-SHASTANY-F15S2G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 19
总计 8,470
