跳转到主内容
Lenovo IdeaPad Flex 6-14IKB RAM Replacement
你所需要的
  1. Lenovo IdeaPad Flex 6-14IKB RAM Replacement, Base Cover: 步骤 1 中的图像 1,1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB RAM Replacement, RAM: 步骤 3 中的图像 1,1
    • Use the plastic opening tool to pry the protective cover off of the RAM.
  4. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad Flex 6-14IKB RAM Replacement: 步骤 4 中的图像 2,2
    • Unfasten the metal clips that secure the RAM.
  5. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: 步骤 5 中的图像 1,3 Lenovo IdeaPad Flex 6-14IKB RAM Replacement: 步骤 5 中的图像 2,3 Lenovo IdeaPad Flex 6-14IKB RAM Replacement: 步骤 5 中的图像 3,3
    • Remove the RAM from its slot on the motherboard.
结论
一条评论
Thank you so much
Ayham Ka - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 32
总计 704
