跳转到主内容
Lenovo IdeaPad Flex 5-1570 Touchpad Replacement
你所需要的
  1. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Back Panel: 步骤 1 中的图像 1,2 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 步骤 2 中的图像 1,3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 步骤 2 中的图像 2,3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 步骤 3 中的图像 2,2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Battery: 步骤 4 中的图像 1,2 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 步骤 5 中的图像 1,3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 步骤 5 中的图像 2,3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 步骤 5 中的图像 3,3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  6. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Touchpad: 步骤 6 中的图像 1,3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Touchpad: 步骤 6 中的图像 2,3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Touchpad: 步骤 6 中的图像 3,3
    • Using the plastic opening tool, unlock the four ZIF connectors to release the flat cables.
    • Disconnect the four flat cables from the motherboard.
  7. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 步骤 7 中的图像 1,1
    • Using the JIS #000 screwdriver, remove six 2mm screws holding the trackpad down to the device.
  8. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 步骤 8 中的图像 1,1
    • Using the plastic opening tool, remove the silver piece of tape holding the touchpad to the device.
  9. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 步骤 9 中的图像 1,3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 步骤 9 中的图像 2,3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 步骤 9 中的图像 3,3
    • Insert the plastic opening tool underneath the touchpad.
    • Lift it up and remove the touchpad from the device.
结论
Justin Ogihara
于09/18/17注册
27,215 声望
创作了52篇指南
团队
EDU Team EDU Team 的会员
Staff
7 名成员
创作了637篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 49
总计 1,451
