跳转到主内容
Lenovo IdeaPad Flex 5-1570 Speaker Replacement
你所需要的
  1. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 步骤 2 中的图像 1,3 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 步骤 2 中的图像 2,3 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 步骤 3 中的图像 2,2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Remove the three 5 mm Phillips #00 screws that secure the hard drive.
  5. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 步骤 5 中的图像 2,2
    • Using your hands, gently pull the hard drive back, sliding it out from the port.
  6. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Speakers: 步骤 6 中的图像 1,3 Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Speakers: 步骤 6 中的图像 2,3 Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Speakers: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using the iFixit nylon tipped tweezers, disconnect the wire that connects the speakers to the motherboard.
  7. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 步骤 7 中的图像 1,2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 步骤 7 中的图像 2,2
    • Using your hands, gently pull the left speaker up and out of the device.
  8. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 步骤 8 中的图像 1,2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 步骤 8 中的图像 2,2
    • Repeat the previous step for the other speaker and remove the speakers from the device.
结论
Nate Blake
于01/23/20注册
507 声望
创作了4篇指南
团队
Cal Poly, Team S2-G6, White Winter 2020 Cal Poly, Team S2-G6, White Winter 2020 的会员
CPSU-WHITE-W20S2G6
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 492
