跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide will show you how to remove and replace the RAM module on your Lenovo IdeaPad Flex 5 1570. The RAM, or Random Access Memory, is responsible for the short term storage of data in your computer. Problems will the RAM will manifest in the use of your computer, rather than its startup like the storage component. If you experience glitches or frequent crashes, this may point to an issue in the RAM and you should consider a replacement. On the other hand, if your computer runs slowly or is constantly held up by compute-intensive programs, you may benefit from the speed boost that a RAM upgrade offers. Regardless of your need, the Lenovo Flex 5 1570 is equipped with a single DDR4 RAM slot, so plan accordingly by acquiring one new RAM stick, rather than two.
  1. Remove  the ten 5 mm Phillips #00 screws that are holding the back panel on. Remove  the ten 5 mm Phillips #00 screws that are holding the back panel on.
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Use a spudger to pry open the back case at the two hinge cutouts. Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel. Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Once all the clips have been disengaged, lift off the back cover. Once all the clips have been disengaged, lift off the back cover.
    • Once all the clips have been disengaged, lift off the back cover.
  4. Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard. Be sure to apply even pressure across the wires and connector to not damage the battery cable. Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
  5. Push the two tabs on both sides of the RAM stick apart to release the memory module. The RAM will rise up to rest at an angle to the motherboard. The RAM will rise up to rest at an angle to the motherboard.
    • Push the two tabs on both sides of the RAM stick apart to release the memory module.
    • The RAM will rise up to rest at an angle to the motherboard.
  6. Pull the RAM stick out of its port with respect to the angle at which it rests. Be sure to handle the edges of the RAM card, as the oil on your skin can have damaging effects to the circuits or pins. Be sure to handle the edges of the RAM card, as the oil on your skin can have damaging effects to the circuits or pins.
    • Pull the RAM stick out of its port with respect to the angle at which it rests.
    • Be sure to handle the edges of the RAM card, as the oil on your skin can have damaging effects to the circuits or pins.
结论
Austin Blakely
于2019年03月11日注册
8,172 信誉积分
创作了46篇指南
团队
iFixit iFixit 的会员
Community
133 名成员
创作了15,614篇指南
添加评论
浏览统计数据:
过去的24小时: 3
过去的7天: 10
过去的30天: 29
总计 66
