跳转到主内容
Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement
你所需要的
  1. Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement, Wireless Network Adapter: 步骤 3 中的图像 1,2 Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement, Wireless Network Adapter: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use the reverse tweezers to carefully unplug the two wired connections.
    • Be careful when removing the wire connections to avoid damage to the metal connections on the adapter.
  4. Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement: 步骤 4 中的图像 2,2
    • Using the Phillips #00 screwdriver, remove one 3.6 mm screw.
  5. Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement: 步骤 5 中的图像 1,1
    • Remove the wireless network adapter.
结论
另外一个人完成了本指南。
Emily Lau
于01/23/20注册
120 声望
撰写一个指南
团队
Cal Poly, Team S2-G5, White Winter 2020 Cal Poly, Team S2-G5, White Winter 2020 的会员
CPSU-WHITE-W20S2G5
4 名成员
创作了16篇指南
一条评论
Thank you!
My problem now is the replacement of the tiny male connectors which hooks onto the chip. They are shown in the last image above at the end of the white wire!
I do not know where to get them, given that mine were broken off.
I would deeply appreciate your help in identifying this type of connectors and locating a sources!
Apart from that, as usual, an excellent and up-to-the-point review.
Thank you again.
Dr. Khaled Bizri,
(650) 796 5864
Khaled.Bizri@GMail.com
Khaled Bizri - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 40
总计 4,663
