跳转到主内容
Lenovo IdeaPad Flex 5-1470 Motherboard Replacement
你所需要的
  1. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, SSD: 步骤 3 中的图像 1,1
    • Remove the single 3.6 mm screw using a Phillips #00 screwdriver.
    • The SSD will pop up on its own after removing the screw.
  4. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,3 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: 步骤 4 中的图像 2,3 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: 步骤 4 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the three screws securing the fan.
    • Lift the fan up and out.
    • Use a Phillips #00 screwdriver to remove the three screws securing the hard drive.
    • Lift the hard drive up and out.
  5. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the single screw securing the Wi-Fi card.
    • The Wi-Fi card will slightly lift away from the motherboard.
    • Pull the Wi-Fi card directly out of its port.
  6. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: 步骤 6 中的图像 1,2 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the three screws securing the motherboard.
    • Gently disconnect the cables and ribbon cables connected to the motherboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 479
