跳转到主内容
Lenovo IdeaPad Flex 5-1470 Display Replacement
你所需要的
  1. Lenovo IdeaPad Flex 5-1470 Display Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Display Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad Flex 5-1470 Display Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Display Replacement, Motherboard: 步骤 3 中的图像 1,3 Lenovo IdeaPad Flex 5-1470 Display Replacement, Motherboard: 步骤 3 中的图像 2,3 Lenovo IdeaPad Flex 5-1470 Display Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the three screws securing the fan.
    • Lift the fan up and out.
    • Use a Phillips #00 screwdriver to remove the three screws securing the hard drive.
    • Lift the hard drive up and out.
  4. Lenovo IdeaPad Flex 5-1470 Display Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad Flex 5-1470 Display Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the single screw securing the Wi-Fi card.
    • The Wi-Fi card will slightly lift away from the motherboard.
    • Pull the Wi-Fi card directly out of its port.
  5. Lenovo IdeaPad Flex 5-1470 Display Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad Flex 5-1470 Display Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the three screws securing the motherboard.
    • Gently disconnect the cables and ribbon cables connected to the motherboard.
  6. Lenovo IdeaPad Flex 5-1470 Display Replacement, Display: 步骤 6 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the four 5 mm screws from the left and right hinges (two screws on each hinge).
  7. Lenovo IdeaPad Flex 5-1470 Display Replacement: 步骤 7 中的图像 1,3 Lenovo IdeaPad Flex 5-1470 Display Replacement: 步骤 7 中的图像 2,3 Lenovo IdeaPad Flex 5-1470 Display Replacement: 步骤 7 中的图像 3,3
    • Disconnect the display assembly from the rest of the device by separating the hinges of the display from the body of the laptop.
    • Use a spudger to carefully pry loose the two screw covers (one on each hinge).
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws from the display (one on each side).
  8. Lenovo IdeaPad Flex 5-1470 Display Replacement: 步骤 8 中的图像 1,2 Lenovo IdeaPad Flex 5-1470 Display Replacement: 步骤 8 中的图像 2,2
    • Use a heat gun or an iOpener to lightly heat the outer edges of the display, loosening the adhesive strips.
    • Wedge a Jimmy or opening picks between the display and display housing, then carefully pry around the entire perimeter until the display separates from the housing.
  9. Lenovo IdeaPad Flex 5-1470 Display Replacement: 步骤 9 中的图像 1,1
    • Disconnect the display ribbon cable.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 43
总计 1,608
