跳转到主内容
Lenovo IdeaPad Flex 4-1470 Touchpad Replacement
你所需要的
  1. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: 步骤 2 中的图像 2,2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Battery: 步骤 3 中的图像 1,2 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Battery: 步骤 3 中的图像 2,2
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: 步骤 4 中的图像 1,1
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: 步骤 5 中的图像 1,1
    • Lift the battery up and out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Touchpad: 步骤 6 中的图像 1,1
    • Locate the touchpad.
  7. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: 步骤 7 中的图像 1,2 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: 步骤 7 中的图像 2,2
    • Remove the three ribbon cables surrounding the touch pad.
  8. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: 步骤 8 中的图像 1,1
    • Lift the base of the laptop from the screen and gently push the touchpad to remove.
结论
2等其他人完成本指南。
Elijah Ellis
于11/08/18注册
616 声望
创作了5篇指南
团队
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 的会员
UMASSD-GULBRANDSEN-F18S5G2
3 名成员
创作了5篇指南
2条评论
do you know where to find this part? i have been looking everywhere haha.
Hanna Tafete - 回复
Can any body repair lenovo idea pad 1470. Touch screen ...tia
jgonzales - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,221
