跳转到主内容
Lenovo IdeaPad Flex 4-1470 Removing the Lower Case
你所需要的
  1. Lenovo IdeaPad Flex 4-1470 Removing the Lower Case, Lower Case: 步骤 1 中的图像 1,1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Removing the Lower Case: 步骤 2 中的图像 1,2 Lenovo IdeaPad Flex 4-1470 Removing the Lower Case: 步骤 2 中的图像 2,2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
结论
6等其他人完成本指南。
Demario Robinson
于10/02/17注册
1,038 声望
创作了4篇指南
团队
USF Tampa, Team S1-G6, Thompson Fall 2017 USF Tampa, Team S1-G6, Thompson Fall 2017 的会员
USFT-THOMPSON-F17S1G6
3 名成员
创作了10篇指南
一条评论
can someone please tell me where to find the back cover? i need to order it
angel etoile - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 56
总计 19,341
