跳转到主内容
Lenovo IdeaPad Flex 4-1470 RAM Replacement
你所需要的
  1. Lenovo IdeaPad Flex 4-1470 RAM Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 RAM Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad Flex 4-1470 RAM Replacement: 步骤 2 中的图像 2,2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 RAM Replacement, RAM: 步骤 3 中的图像 1,2 Lenovo IdeaPad Flex 4-1470 RAM Replacement, RAM: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • RAM cards can be damaged from exposure to a static charge through contact with the hand or other body parts. Though the damage of one discharge is not severe, multiple exposures can cause your RAM to fail.
    • When changing the RAM please wear an anti-static wrist strap on your dominant hand and attach the alligator clips to one of the screw holes in the laptop body.
    • Using a metal spudger, pry the RAM cover out of the clips on the motherboard. You will need to go around all sides.
    • Remove the cover.
    • When replacing the cover make sure it is in all of the clips.
  4. Lenovo IdeaPad Flex 4-1470 RAM Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad Flex 4-1470 RAM Replacement: 步骤 4 中的图像 2,2
    • To remove the RAM card simply pull the clips on the sides outwards and the RAM will tilt up.
    • Gently pull the RAM out of the motherboard.
    • When inserting a new RAM card, ensure you put it in at an angle just like it came out. Then push it down into the clips.
结论
10等其他人完成本指南。
Demario Robinson
于10/02/17注册
1,038 声望
创作了4篇指南
团队
USF Tampa, Team S1-G6, Thompson Fall 2017 USF Tampa, Team S1-G6, Thompson Fall 2017 的会员
USFT-THOMPSON-F17S1G6
3 名成员
创作了10篇指南
5条评论
I am an older lady and I know I couldn;t possibly do that,do you have any advice
diane nodwell - 回复
To Diane: Take your device to Best Buy Geek Squad or to Device Pit Stop. Otherwise, Do you have a skilled nephew / neighbor who can replicate this?
Raul Soria - 回复
Can you please confirm if the DDR4 PC4-21300 RAM is accepted by the Flex4? Thanks!
Raul Soria - 回复
SIW shows as if there are two memory slots.
Serg Strikov - 回复
Hey there,
Any suggestions on which RAM card to buy to replace this one? I have 2 GB of RAM now that came with the laptop and I obviously want to replace it to try and speed up my Lenovo. Will it damage the laptop if the RAM is “too much” for the pc? Can I find a single RAM card that is more than 8 GB or faster? What GB do you suggest for faster speeds?
Thanks for your help.
Christine Portanova - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 68
总计 9,503
