跳转到主内容
Lenovo IdeaPad Flex 4-1470 Motherboard Replacement
你所需要的
  1. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: 步骤 3 中的图像 1,2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: 步骤 3 中的图像 2,2
    • Remove the two 4 mm Phillips #0 screws which mount the fan.
  4. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 步骤 4 中的图像 1,3 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 步骤 4 中的图像 2,3 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Using the Precision Tweezers, remove the 2 gray wires around the fan from their clips.
  5. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Use 2 plastic opening tools to remove the fans power wire from the Mother board and remove the fan.
    • Lift the cooling fan out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Wifi Card: 步骤 6 中的图像 1,1
    • Remove the foam on the WIFI card.
  7. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the wires attached to the WIFI card.
  8. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Unscrew the 4mm screw holding wifi card.
  9. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,1
    • Unscrew the twelve 4mm screws with a #0 Phillips screwdriver.
  10. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the motherboard.
    • The motherboard will be in place when the screw holes line up.
结论
2等其他人完成本指南。
Elijah Ellis
于11/08/18注册
616 声望
创作了5篇指南
团队
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 的会员
UMASSD-GULBRANDSEN-F18S5G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 1,272
