跳转到主内容
Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement
你所需要的
  1. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: 步骤 2 中的图像 2,2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Cooling Fan: 步骤 3 中的图像 1,2 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Cooling Fan: 步骤 3 中的图像 2,2
    • Remove the two 4 mm Phillips #0 screws which mount the fan.
  4. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: 步骤 4 中的图像 1,3 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: 步骤 4 中的图像 2,3 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using the Precision Tweezers, remove the 2 gray wires around the fan from their clips.
  5. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: 步骤 5 中的图像 2,2
    • Use 2 plastic opening tools to remove the fans power wire from the Mother board and remove the fan.
    • Lift the cooling fan out of the laptop.
结论
另外一个人完成了本指南。
Demario Robinson
于10/02/17注册
1,038 声望
创作了4篇指南
团队
USF Tampa, Team S1-G6, Thompson Fall 2017 USF Tampa, Team S1-G6, Thompson Fall 2017 的会员
USFT-THOMPSON-F17S1G6
3 名成员
创作了10篇指南
一条评论
will the same fan fit to lenovo ideapad flex 5 1470 ?
Rajeshwar Choudhary - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 1,624
