跳转到主内容
Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement
你所需要的
  1. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: 步骤 2 中的图像 2,2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement, Cmos battery: 步骤 3 中的图像 1,1
    • Using the JIS #0 screwdriver unscrew the three battery screws.
  4. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: 步骤 4 中的图像 1,1
    • Lift up the battery from the long, bottom edge.
    • Remove the battery from the laptop and place it nearby.
  5. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: 步骤 5 中的图像 2,2
    • Remove the red and black annotated cable, pulling white head out of black port as indicated.
  6. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: 步骤 6 中的图像 1,1
    • Ply the CMOS battery off with your finger.
    • The battery is attached to the computer by adhesive, but should come off by pulling with fingers; plying tool should not be necessary.
结论
2等其他人完成本指南。
Elijah Ellis
于11/08/18注册
616 声望
创作了5篇指南
团队
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 的会员
UMASSD-GULBRANDSEN-F18S5G2
3 名成员
创作了5篇指南
一条评论
Does this procedure reset the BIOS?
Mark Webb - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 2,611
