跳转到主内容
Lenovo IdeaPad Flex 4-1470 Battery Replacement
你所需要的
  1. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Battery Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad Flex 4-1470 Battery Replacement: 步骤 2 中的图像 2,2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Battery: 步骤 3 中的图像 1,2 Lenovo IdeaPad Flex 4-1470 Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Battery Replacement: 步骤 5 中的图像 1,1
    • Lift the battery up and out of the laptop.
结论
9等其他人完成本指南。
Demario Robinson
于10/02/17注册
1,038 声望
创作了4篇指南
团队
USF Tampa, Team S1-G6, Thompson Fall 2017 USF Tampa, Team S1-G6, Thompson Fall 2017 的会员
USFT-THOMPSON-F17S1G6
3 名成员
创作了10篇指南
2条评论
thank for sharing this! I want to check if it is easy to swap HDD/SSD?
pama - 回复
I'm grateful for the individuals who take time to share their knowledge. I'm 63yrs young with no technical skills. I followed your step by step instructions and was successful in changing my laptop battery. THANK YOU! 👩‍🦳👍
iamelara - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 29
总计 13,939
