跳转到主内容
Lenovo IdeaPad Flex 4-1130 Touchpad Replacement
你所需要的
  1. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Remove the ten 4mm screws from the back panel.
  2. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: 步骤 2 中的图像 1,1
    • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Do not insert the spudger too deep! This could potentially damage a device part.
  3. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: 步骤 3 中的图像 1,1
    • Remove the connector attaching the battery to the motherboard.
  4. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: 步骤 4 中的图像 1,1
    • Remove the four 4mm screws on the battery.
  5. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: 步骤 5 中的图像 1,1
    • Lift the battery with a spudger and remove.
  6. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Remove eleven 6mm screws.
  7. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: 步骤 7 中的图像 1,1
    • Lift up black flap on the ZIF connector and pull the ribbon cable out.
  8. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: 步骤 8 中的图像 1,1
    • Lift up on the black tab on the ZIF connector and pull the ribbon cable out.
  9. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: 步骤 9 中的图像 1,1
    • Remove connector cable.
  10. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: 步骤 10 中的图像 1,1
    • Remove one last connector cable.
    • Motherboard should now be completely disconnected and can be lifted off the cover to be replaced.
  11. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement, Touchpad: 步骤 11 中的图像 1,1
    • Due to the amount of force required to remove the screws holding the touchpad, we recommend removing the motherboard before attempting this replacement to reduce the chances of damaging any components.
    • Lift up the black tab on the ZIF connector and pull the ribbon cable out.
  12. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: 步骤 12 中的图像 1,2 Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: 步骤 12 中的图像 2,2
    • Remove three 8mm screws.
  13. Lenovo IdeaPad Flex 4-1130 Touchpad Replacement: 步骤 13 中的图像 1,1
    • Push the touchpad outwards to remove it.
结论
Adrian Miranda
于02/15/18注册
677 声望
创作了5篇指南
团队
USF Tampa, Team S17-G5, Boczar Spring 2018 USF Tampa, Team S17-G5, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S17G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 12
总计 666
