跳转到主内容
Lenovo IdeaPad Flex 4-1130 Motherboard Replacement
你所需要的
  1. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Remove the ten 4mm screws from the back panel.
  2. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Do not insert the spudger too deep! This could potentially damage a device part.
  3. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the connector attaching the battery to the motherboard.
  4. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the four 4mm screws on the battery.
  5. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Lift the battery with a spudger and remove.
  6. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Remove eleven 6mm screws.
  7. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Lift up black flap on the ZIF connector and pull the ribbon cable out.
  8. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Lift up on the black tab on the ZIF connector and pull the ribbon cable out.
  9. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove connector cable.
  10. Lenovo IdeaPad Flex 4-1130 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove one last connector cable.
    • Motherboard should now be completely disconnected and can be lifted off the cover to be replaced.
结论
Adrian Miranda
于02/15/18注册
677 声望
创作了5篇指南
团队
USF Tampa, Team S17-G5, Boczar Spring 2018 USF Tampa, Team S17-G5, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S17G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 909
