跳转到主内容
Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement
你所需要的
  1. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
  2. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: 步骤 2 中的图像 1,1
    • Pop off the back panel using a plastic opening tool once all screws are removed.
  3. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: 步骤 3 中的图像 1,1
    • Once the panel is fully removed, begin to unscrew the battery.
  4. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: 步骤 4 中的图像 2,2
    • Use the iFixit Opening tool to disconnect the battery from the circuit board.
    • When all screws are removed from the battery, carefully lift the battery up.
  5. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: 步骤 5 中的图像 1,1
    • The battery is completely removed, and can be replaced with a new battery.
  6. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement, Touchpad: 步骤 6 中的图像 1,1
    • After battery is removed, you will move to the touchpad.
  7. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: 步骤 7 中的图像 1,1
    • Before removing touchpad you will have to disconnect it from the circuit board using a nylon spudger.
  8. Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: 步骤 8 中的图像 1,2 Lenovo IdeaPad FLEX 4-1580 Touchpad Replacement: 步骤 8 中的图像 2,2
    • Remove all the screws holding the touchpad down.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 559
