跳转到主内容
Lenovo IdeaPad 5 15ITL05 Battery Replacement
你所需要的
  1. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Unfasten the back cover: 步骤 1 中的图像 1,2 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Unfasten the back cover: 步骤 1 中的图像 2,2
    • Use a T5 Torx driver to remove nine screws securing the back cover.
    • The three screws on the hinge side will be longer.
  2. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 2 Loosen the back cover: 步骤 2 中的图像 1,3 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 2 Loosen the back cover: 步骤 2 中的图像 2,3 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 2 Loosen the back cover: 步骤 2 中的图像 3,3
    • The back cover is held on by plastic tabs around the entire perimeter of the cover.
    • Use plastic pry tools at the seam. I like to start near the hinge.
  3. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 3 Remove the back cover: 步骤 3 中的图像 1,2 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 3 Remove the back cover: 步骤 3 中的图像 2,2
    • Once all the tabs are loose, you will be able to remove the cover.
  4. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Disconnect the battery: 步骤 4 中的图像 1,2 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Disconnect the battery: 步骤 4 中的图像 2,2
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  5. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Unfasten the battery: 步骤 5 中的图像 1,1
    • Use a Phillips screwdriver to remove the four screws securing the battery.
    • Note: Two of the screws on the left in the image will also hold in the SATA drive bracket.
  6. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 6 Remove the battery: 步骤 6 中的图像 1,1
    • Remove the battery.
结论
E N
于11/21/22注册
422 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 76
总计 407
