跳转到主内容
Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement
你所需要的
  1. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement, USB/SD Ports: 步骤 1 中的图像 1,1
    • Begin by placing your laptop upside down so that you can see the labels on the back.
  2. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: 步骤 2 中的图像 1,1
    • Remove the 10 silver screws from the bottom of the laptop.
    • Keep these screws in a safe place like a magnetic board to keep them from getting lost.
    • (Silver, 5.8mm Phillips #0)
  3. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the back panel from the laptop.
    • Proceed slowly and use wedges to avoid damaging the panel.
  4. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: 步骤 4 中的图像 1,1
    • Locate the USB/SD Ports in the top left corner of the laptop.
  5. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: 步骤 5 中的图像 1,1
    • Remove the two black screws holding the USB/SD port in place.
    • (Black, 3.35mm Phillips #0)
  6. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: 步骤 6 中的图像 1,1
    • Gently disconnect the black and red wires from the board.
    • Be sure not to pull too hard on the wires.
  7. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: 步骤 7 中的图像 1,1
    • Remove the blue cable from the board.
  8. Lenovo IdeaPad 330S-14IKB USB/SD Ports Replacement: 步骤 8 中的图像 1,1
    • Remove your old USB/SD ports
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 97
