跳转到主内容
Lenovo IdeaPad 330S-14IKB Battery Replacement
你所需要的
  1. Lenovo IdeaPad 330S-14IKB Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Begin by turning your laptop upside down so that you can access the labels on the back.
  2. Lenovo IdeaPad 330S-14IKB Battery Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad 330S-14IKB Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the 10 screws from the bottom of the laptop.
    • Safely store these screws in a place where you won't lose them, such as a magnetic pad.
    • (Silver, 5.8mm Philips #0)
  3. Lenovo IdeaPad 330S-14IKB Battery Replacement: 步骤 3 中的图像 1,1
    • Slowly and carefully remove the back panel from the laptop.
    • Be cautious and use wedges if needed to avoid damaging the panel.
  4. Lenovo IdeaPad 330S-14IKB Battery Replacement: 步骤 4 中的图像 1,1
    • Locate the battery in the bottom left corner.
  5. Lenovo IdeaPad 330S-14IKB Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the 5 screws that secure the battery in place.
    • (Black, 3.45mm Phillips #0)
  6. Lenovo IdeaPad 330S-14IKB Battery Replacement: 步骤 6 中的图像 1,2 Lenovo IdeaPad 330S-14IKB Battery Replacement: 步骤 6 中的图像 2,2
    • Near the positive and negative symbols on the battery, you'll find a wire connected to the motherboard.
    • Gently unplug this wire.
  7. Lenovo IdeaPad 330S-14IKB Battery Replacement: 步骤 7 中的图像 1,2 Lenovo IdeaPad 330S-14IKB Battery Replacement: 步骤 7 中的图像 2,2
    • There is a wire clipped to the side of the battery next to the hard drive; unhook this wire.
    • With the wire disconnected, remove the old battery.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 21
总计 260
