跳转到主内容
Lenovo IdeaPad 330S Wireless Lan Card Replacement
你所需要的
  1. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing Bottom Case: 步骤 1 中的图像 1,2 Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing Bottom Case: 步骤 1 中的图像 2,2
    • Turn the device off.
    • Remove the 10 screws as shown in picture.
    • Using a pry tool , remove the bottom case.
  2. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Disconnecting Battery: 步骤 2 中的图像 1,1
    • Using a spudger gently push the plastic connector to the left in order to disconnect the battery.
  3. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing guard shield: 步骤 3 中的图像 1,1
    • Remove the three 00# screws.
    • Remove the 2.5 mm screw.
    • Gently pry the shield.
  4. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing Wireless Card: 步骤 4 中的图像 1,1
    • Before removing the screw (marked in red circle) remove the two antenna cables using the spudger.
    • Remove the screw.
    • The wireless card will lift, remove it.
    • Install the new wireless card.
结论
另外一个人完成了本指南。
Ilia Tocheny
于04/30/19注册
1,616 声望
创作了9篇指南
2条评论
So my laptop sometimes has no bluetooth, or wifi, or both. A quick reboot fixes it, but idk if the module is actually faulty. I've opened it before, and don't want to buy a replacement chip if this one is just seated poorly. Is there a good way to check. Thanks
Calvin Mills - 回复
Using the correct tools try to disconnect the cables from the socket and reseat them in the socket make just do as the guide but without removing the WLAN card
Ilia Tocheny -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 66
总计 3,214
