跳转到主内容
Lenovo IdeaPad 330S RAM Replacement
你所需要的
  1. Lenovo IdeaPad 330S RAM Replacement, Removing bottom case: 步骤 1 中的图像 1,2 Lenovo IdeaPad 330S RAM Replacement, Removing bottom case: 步骤 1 中的图像 2,2
    • Please turn off the laptop before opening the device
    • Remove the 10 screws as shown in the picture.
    • Gently using the tool pry off the bottom case
  2. Lenovo IdeaPad 330S RAM Replacement, Disconnecting Battery: 步骤 2 中的图像 1,1
    • Using a spudger gently push the plastic connector to the left in order to disconnect the battery. wisdom here.
  3. Lenovo IdeaPad 330S RAM Replacement, Removing Black Case: 步骤 3 中的图像 1,2 Lenovo IdeaPad 330S RAM Replacement, Removing Black Case: 步骤 3 中的图像 2,2
    • Remove these screws as show in picture
    • Gently pry out the black case.
    • Note that one of the screws are Philips 2.5 and not Philips (the black screw top right ).
  4. Lenovo IdeaPad 330S RAM Replacement, Removing Ram Stick: 步骤 4 中的图像 1,1
    • Gently using heavy duty spuder remove the old memory
  5. Lenovo IdeaPad 330S RAM Replacement, Installing Ram Stick: 步骤 5 中的图像 1,1
    • Arrange the new ram stick accoring the pin on the motherboard
    • Push Gently on the stick until you hear two clicks
结论
To reassemble the device, install your new stick(s) and follow these instructions in reverse order.
6等其他人完成本指南。
Ilia Tocheny
于04/30/19注册
1,616 声望
创作了9篇指南
8条评论
Is it possible to upgrade the cpu of my lenovo 330s which is a core i3 7gen to say a core i5 10th gen
Nathan D'souza - 回复
Only by replacement or the Motherboard…
The CPU is soldered to the M.B. and cannot upgraded easily
Ilia Tocheny - 回复
Hallo.
I am Japanese Hegt Stuident.
Do I need to remove the battery when removing the RAM?
(こんにちは。
日本の高校生です。
RAMを外すとき、バッテリーは外す必要がありますか?)
Muromi - 回复
You can disconnect the battery no need of removing it.
Ilia Tocheny -
I just Updated the repair guide of memory replacement.
Ilia Tocheny - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 32
过去 30 天: 114
总计 7,220
