跳转到主内容
Lenovo IdeaPad 330S Fan and Thermal Unit
你所需要的
  1. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing bottom case: 步骤 1 中的图像 1,2 Lenovo IdeaPad 330S Fan and Thermal Unit, Removing bottom case: 步骤 1 中的图像 2,2
    • Turn off the device and disconnect from the power.
    • Remove the 10 screws as shown in picture.
    • Using a plastic pry tool remove the bottom case (gently).
  2. Lenovo IdeaPad 330S Fan and Thermal Unit, Disconnecting Battery: 步骤 2 中的图像 1,1
    • Using a spudger gently push the black connector to the left (red circle).
    • If you want to remove the battery by removing the five screws labeled in blue.
  3. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing guard shield: 步骤 3 中的图像 1,2 Lenovo IdeaPad 330S Fan and Thermal Unit, Removing guard shield: 步骤 3 中的图像 2,2
    • Remove the 3 screws that are circuled in blue. Then remove the red one.
    • The red circle is a M2.5 and the blue circle are M2.0 those are different screws!
    • Remove the black shield
  4. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing Cooling Fan: 步骤 4 中的图像 1,1
    • Remove the two black screws that are marked in red
    • Disconnect the fan (blue marker) from MB by pushing gently to the left using a spudger.
  5. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing the Thermal unit: 步骤 5 中的图像 1,1
    • Remove the 6 screws in revrse of the number stated on screws.
    • Replace the thermal paste with a fresh one
    • Removing the fan is not needed but will help with easier dissemble of thermal unit
结论
3等其他人完成本指南。
Ilia Tocheny
于04/30/19注册
1,616 声望
创作了9篇指南
2条评论
I want to buy this piece, where can I find it for purchase?
c.lobos_7 - 回复
Good question, you could try at your local Lenovo Service provider.
Ilia Tocheny - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 1,633
