跳转到主内容
Lenovo IdeaPad 330-15IGM Speaker Units Replacement
你所需要的
  1. Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Back Cover: 步骤 1 中的图像 1,3 Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Back Cover: 步骤 1 中的图像 2,3 Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Press and hold the power button to power off the computer.
  2. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 步骤 2 中的图像 1,1
    • Remove thirteen 6.5 mm screws from the laptop cover using a Phillips #00 screwdriver.
  3. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 步骤 3 中的图像 1,1
    • Use your hands to remove the back cover from the laptop.
  4. Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Battery: 步骤 4 中的图像 1,1
    • Remove four 5.7 mm screws that hold the battery unit in place using a Phillips #00 screwdriver.
  5. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 步骤 5 中的图像 1,3 Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 步骤 5 中的图像 2,3 Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 步骤 5 中的图像 3,3
    • Detach the cable connecting the battery to the motherboard.
  6. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 步骤 6 中的图像 1,1
    • Remove the battery from the laptop.
  7. Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Speaker Units: 步骤 7 中的图像 1,2 Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Speaker Units: 步骤 7 中的图像 2,2
    • Carefully disconnect the speaker from the motherboard.
    • Each speaker unit has blue stoppers that allow it to remain in place. In order to remove the unit, you must nudge the blue stoppers off of the plastic piece it is attached to. Repeat for each speaker.
  8. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 步骤 8 中的图像 1,3 Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 步骤 8 中的图像 2,3 Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 步骤 8 中的图像 3,3
    • Remove the unit from the chassis and carefully remove the cable that connects the two speaker units together.
    • This cable is vital since it is the only thing that connects the speaker units and allows them to share audio from the motherboard.
结论
团队
Gateway, Team 1-2, Class Fall 2022 Gateway, Team 1-2, Class Fall 2022 的会员
GCC-CLASS-F22S1G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 121
