跳转到主内容
Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement
你所需要的
  1. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Remove all Phillips #0 screws securing the case to the laptop.
  2. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: 步骤 2 中的图像 2,2
    • Pry all edges off of the laptop with the opening tool until the lower case releases.
    • Remove the lower case.
  3. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 1,3 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 2,3 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement, Wi-Fi Card: 步骤 3 中的图像 3,3
    • Remove the two Wi-Fi card's connections by gently lifting up on the connectors.
  4. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: 步骤 4 中的图像 1,3 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: 步骤 4 中的图像 2,3 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: 步骤 4 中的图像 3,3
    • Remove the single Phillips #0 screw securing the Wi-Fi card.
  5. Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad 330-15ARR Wi-Fi Card Replacement: 步骤 5 中的图像 2,2
    • Slide the Wi-Fi card out of its port on the motherboard.
    • Do not worry about the angle the card sits after removing the mounting screw - this is how it's meant to be connected and will have to be connected similarly during reassembly.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 26
总计 257
