跳转到主内容
简介
This guide is necessary for times when the RAM is thought to be the cause of slow response times or blank screens. Replacing or reseating the RAM may increase the system's speed or fix blank screen issues.
  1. Unplug the power cable from the wall before performing replacement to avoid electrocution. Flip the laptop over.
    • Unplug the power cable from the wall before performing replacement to avoid electrocution.
    • Flip the laptop over.
  2. Android 维修工具包
    A new screen or battery is one kit away.
    现在开始购物
    Android 维修工具包
    现在开始购物
  3. Remove the single Phillips #0 screw that is holding down the battery and ram panel. Remove the battery and ram panel.
    • Remove the single Phillips #0 screw that is holding down the battery and ram panel.
    • Remove the battery and ram panel.
  4. Remove the RAM by pushing the two metal clamps away from each other length-wise on the chip. After hearing a click sound, pull the RAM out from the brackets. After hearing a click sound, pull the RAM out from the brackets.
    • Remove the RAM by pushing the two metal clamps away from each other length-wise on the chip.
    • After hearing a click sound, pull the RAM out from the brackets.
结论
2等其他人完成本指南。
Richard
于2017年09月21日注册
303 信誉积分
创作了2篇指南
团队
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 17
总计 829
