跳转到主内容
  1. Flip laptop over Remove 13 screws to remove bottom.  Size: Phillips #0
    • Flip laptop over
    • Remove 13 screws to remove bottom. Size: Phillips #0
    • Remove extra 3 screws from RAM port. Size: Phillips #0
  2. Disconnect keyboard and touchpad Remove CD drive
    • Disconnect keyboard and touchpad
    • Remove CD drive
  3. Android 维修工具包
    A new screen or battery is one kit away.
    现在开始购物
    Android 维修工具包
    现在开始购物
  4. Flip laptop back over Using a plastic spudger, pry between the keyboard panel and bottom panel on all 4 sides.
    • Flip laptop back over
    • Using a plastic spudger, pry between the keyboard panel and bottom panel on all 4 sides.
  5. Remove 4 screws and tabs holding motherboard Be sure to disconnect fan tab on the bottom of the motherboard Be sure to disconnect fan tab on the bottom of the motherboard
    • Remove 4 screws and tabs holding motherboard
    • Be sure to disconnect fan tab on the bottom of the motherboard
  6. Remove 1 fan screw. Size: Phillips #0
    • Remove 1 fan screw. Size: Phillips #0
结论
msegundo23
于2017年09月21日注册
201 信誉积分
创作了2篇指南
团队
添加评论
浏览统计数据:
过去的24小时: 4
过去的7天: 13
过去的30天: 49
总计 1,050
