跳转到主内容
简介
Replace the battery of your Lenovo IdeaPad 310 Touch-15ISK. This simple guide will describe how to access and remove the internal battery for replacement. The battery is fairly buried within the computer so the removal of major components is required.
配件
没有特定配件。
  1. Flip the laptop over and remove the 13 Phillips #1 screws from the bottom panel. Remove the 2 Phillips #1 screws holding RAM panel in and then remove RAM panel
    • Flip the laptop over and remove the 13 Phillips #1 screws from the bottom panel.
    • Remove the 2 Phillips #1 screws holding RAM panel in and then remove RAM panel
  2. Disconnect keyboard and touchpad wire using a soft pry bar. Remove CD port.
    • Disconnect keyboard and touchpad wire using a soft pry bar.
    • Remove CD port.
  3. Flip laptop back over. Using a plastic spudger, pry between the keyboard panel and bottom panel on all 4 sides.
    • Flip laptop back over.
    • Using a plastic spudger, pry between the keyboard panel and bottom panel on all 4 sides.
  4. Remove the 4 Phillips #0 screws holding the motherboard to the computer. Disconnect the fan tab on the bottom of the motherboard. Remove the 5 tabs holding the motherboard to the computer and remove the motherboard.
    • Remove the 4 Phillips #0 screws holding the motherboard to the computer.
    • Disconnect the fan tab on the bottom of the motherboard.
    • Remove the 5 tabs holding the motherboard to the computer and remove the motherboard.
  5. Unscrew the 2 Phillips #0 screws holding the battery in place. Remove wire tab holding battery in place.
    • Unscrew the 2 Phillips #0 screws holding the battery in place.
    • Remove wire tab holding battery in place.
    • Carefully remove battery.
结论
4等其他人完成本指南。
Cam Plute
于2017年09月26日注册
213 信誉积分
撰写一个指南
团队
Step 2 should include removing connectors for the wireless card.
Ronn Richardson - 回复
Thanks for your commentary, I have added this in my French translation but I don’t know why I can’t modify the tutorial in English.. Maybe because I am a French member..
Zacharie Troletti-Gillot -
The fan should also be disconnected in step 2 not step 4.
添加评论
浏览统计数据:
过去的24小时: 3
过去的7天: 56
过去的30天: 236
总计 17,279
