跳转到主内容
Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement
你所需要的
  1. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement, Bottom Back Cover: 步骤 1 中的图像 1,1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: 步骤 2 中的图像 2,2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement, Wireless LAN Card: 步骤 3 中的图像 1,1
    • The wireless LAN card is located at the center of the laptop.
  4. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: 步骤 4 中的图像 1,1
    • Unscrew the 3mm Phillips #1 screw that holds the WLAN card in place.
  5. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: 步骤 5 中的图像 1,1
    • Disconnect the black and white cables from the WLAN card.
  6. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: 步骤 6 中的图像 1,1
    • Gently remove the WLAN card out of its slot.
结论
3等其他人完成本指南。
Ammar Dodin
于01/19/17注册
1,057 声望
创作了6篇指南
团队
UC Davis, Team 1-3, Rodger Winter 2017 UC Davis, Team 1-3, Rodger Winter 2017 的会员
UCD-RODGER-W17S1G3
4 名成员
创作了6篇指南
3条评论
Thanks Ammar, I thought my wifi card was jammed until I saw your post.
Turns out one of the cables (white one) was disconnected which lead to my wifi signal being non-existent. I plugged it in again and its working properly again.
Cheers
Vlottie
David Vlotman - 回复
Thanks for say, white is 1
SABBIR HOSSAIN -
How to connect wire black and white to pin 1 and 2, plz help
SABBIR HOSSAIN - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 16
总计 2,798
