跳转到主内容
Lenovo IdeaPad 300-17ISK RAM Replacement
你所需要的
  1. Lenovo IdeaPad 300-17ISK RAM Replacement, Bottom Back Cover: 步骤 1 中的图像 1,1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK RAM Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad 300-17ISK RAM Replacement: 步骤 2 中的图像 2,2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK RAM Replacement, RAM: 步骤 3 中的图像 1,1
    • The RAM sticks are located near the bottom of the device, and they are arranged next to each other.
  4. Lenovo IdeaPad 300-17ISK RAM Replacement: 步骤 4 中的图像 1,3 Lenovo IdeaPad 300-17ISK RAM Replacement: 步骤 4 中的图像 2,3 Lenovo IdeaPad 300-17ISK RAM Replacement: 步骤 4 中的图像 3,3
    • Locate the two dislocating latches on each side of the stick and place your fingers on them.
    • Pull the tabs away from the stick simultaneously until the stick pops out of place.
    • Gently remove the RAM stick once it has popped out of its place.
    • If necessary, repeat the same process with the second RAM stick that is adjacent to the first one.
结论
To reassemble the device, install your new stick(s) and follow these instructions in reverse order.
另外一个人完成了本指南。
Ammar Dodin
于01/19/17注册
1,057 声望
创作了6篇指南
团队
UC Davis, Team 1-3, Rodger Winter 2017 UC Davis, Team 1-3, Rodger Winter 2017 的会员
UCD-RODGER-W17S1G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 29
总计 2,403
