跳转到主内容
Lenovo IdeaPad 300-17ISK Optical Drive Replacement
你所需要的
  1. Lenovo IdeaPad 300-17ISK Optical Drive Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Unscrew the three 6mm Phillips #1 screws from the upper back cover.
  2. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: 步骤 2 中的图像 1,3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: 步骤 2 中的图像 2,3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: 步骤 2 中的图像 3,3
    • Place the opening tool's head under any edge of the keyboard.
    • Pull upwards to unsnap the keyboard.
    • Use your fingers and the opening tool to pop the keyboard out of its place.
    • You should't use any excessive force because the keyboard is still attached to the motherboard.
  3. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: 步骤 3 中的图像 2,2
    • Push the keyboard connector latch upwards with the spudger.
    • You shouldn't use excessive force. The connector latch is very fragile.
    • The keyboard connector cable should slide right out.
  4. Lenovo IdeaPad 300-17ISK Optical Drive Replacement, Optical Drive: 步骤 4 中的图像 1,1
    • Remove the 6mm Phillips #1 screw that sits in the center of the front plate below the keyboard. This screw sits between two adjacent tabbed holes.
  5. Lenovo IdeaPad 300-17ISK Optical Drive Replacement: 步骤 5 中的图像 1,3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: 步骤 5 中的图像 2,3 Lenovo IdeaPad 300-17ISK Optical Drive Replacement: 步骤 5 中的图像 3,3
    • Insert the opening tool's head into one of the tabbed holes.
    • With the opening tool's head inserted under a tab, push to the right. The optical drive should slide out easily.
结论
另外一个人完成了本指南。
Ammar Dodin
于01/19/17注册
1,057 声望
创作了6篇指南
团队
UC Davis, Team 1-3, Rodger Winter 2017 UC Davis, Team 1-3, Rodger Winter 2017 的会员
UCD-RODGER-W17S1G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 22
总计 5,041
